Out Of Sync
Hi any one has idea what is outfoSync means..& what does it indicate ? if i do sync then what does it do in sync process..
1 REPLY
Re: Out Of Sync
Very basically, it means the startup and running configs are out of sync. That is, there are changes in one configuration which are not in the other. Typically, this occurs because one makes a configuration change, but does not do "write mem".
If you do a Sync in RME, then RME will sync the two configs with a write mem operation.
158
