11-28-2006 04:53 AM
I have a strange issue in LMS 2.5. I am trying to update the packages that are installed (mainly because the Topology View doesn't seem to recognise the 3560G-48TS switches - lists them as CiscoProduct.617), however when I go to the package update section of the interface there are no packages for me to select for update. (i.e. Common Services>Software Centre>Device Update - is devoid of any entries).
Any help greatly appreciated.
Solved! Go to Solution.
11-28-2006 09:07 AM
Campus Manager does not support device updates. This feature is only applicable to Common Services, RME, and CiscoView. Finding no packages for Campus Manager is expected.
If you upgrade to LMS 2.6, you will get support for the 3548G-48TS.
11-29-2006 05:00 AM
That is correct, support is available in LMS 2.6
11-28-2006 09:07 AM
11-29-2006 04:55 AM
Thanks for the reply - does the 2.6 update include support for the 3560G-48TS as well.
This is the device I have most of the "CiscoProduct.617" issues with.
11-29-2006 05:00 AM
