Parameterized Templates for SNMP Chassis-ID
I ask for some qualification please.
My customer has 5000+ devices and wishes to populate the 'snmp-server chassis-id' with serial no.s of each device.
I'm thinking of exporting the serial no. into an XML file and using that file for the Parameterized Template.
Has anyone done this before; does it work or is there a simpler method perhaps?
Kind Regards
David
Re: Parameterized Templates for SNMP Chassis-ID
This should work provided all the devices in question are IOS devices. Your parameterized command file would look something like:
FA123456789
FA24681012
Then your template would be:
snmp-server chassis-id $chassisId
Thanks John,
I'll test it out.
196
