Community Member
Parameters concatenation in LMS4.2.5 XML template
Hello to you all
I am creating several templates to apply with our LMS. I am though struggling with small issue and I hope that someone can help me.
I would like to use one of the variables in the template and add a sufix in order to create our ACL's.
I explain:
ip access-list extended ${Circuit_number}_out
permit ip any
This command is never applied as due to the sufix "_out" the variable doesn't get recognized. I have gone through several documents but haven't found a way to avoid this. I have also tried to use CDDATA but it didn't helped.
If I use a prefix "out_" works as expected
ip access-list extended out_${Circuit_number}
permit ip any
Why does the first example doesn't work but the second does? Any ideas?
LMS version:4.2.5
Best regards
Isaac Alves
