Community Member
Partially Successful state in Archive Management
I have the some number in the "number of devices" field for the Partially Sucessful state in the RME/Config Mgmt Archive Mgmt. But configurations from these devices are fetched in RME database. Can I clear this statistics in the Partially Successful state?
Config Archival Status No. of Devices
Successful 1
Failed 0
Partially Successful 1
Total 2
Thank you
Re: Partially Successful state in Archive Management
There is a database query that can be run to do this, but it is not recommended. Given the small number of devices, you might consider reinitializing the entire RME database. Assuming you are then on the latest version of LMS (LMS 2.6), this problem should not reoccur.
To reinitialize the RME database, use the following command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=rmeng dmprefix=RME
Community Member
Thank you. I try to update LMS to version 2.6.
Roman
128
