Webcast-Catalyst9k
PFC console login
I am trying to connect a console to the active sup 2 on a cat 6500 and it takes me into the msfc directly. why is that ? Is it because I previouse logged in using session mod..... command. How do i exit and back to the L2.
Thanks in advance,
cheers
sundar
1 REPLY
Bronze
Re: PFC console login
You can enter the switch console command to access the MSFC CLI from the supervisor engine CLI directly connected to the console port. To exit from the MSFC CLI and return to the supervisor engine CLI, enter ^C^C^C at the Router> prompt.
99
