PI 2.0 - Interface bulk configuration - Interface Roles
I did some research on how to use CLI configuration template do bulk configure Ports depending on their Port description. I found the Interface Role definition located in "Design --> Shared Policy Objects" which seemed perfect to be used inside a configuration template. It is also written in the User Guide that Interface Roles can be used in configuration templates. The problem for me now is that i did not find out how to use Interface Roles inside custom CLI configuration templates!? The Interface Roles can be choosen inside some pre-defined templeats like the AVC template but apart from that i am not aware how to include Interface Roles in any custom configuration template!?
Does anyone have some experience with this or maybe a link to a more detailed documentation for creating configuration templates? All i found out about CLI templates so far is how to define variables!?
Thanks in advance!
129
