05-05-2014 10:51 AM
Just got my PI 2.0 upgraded to 2.1
I was reading through the release notes and was wondering if PI 2.1 can be used with a 5508 running 7.6.120.0 code. Currently we are running 7.4.100.60 and haven't put any new code on due to PI requirements.
Same goes for our 3555 MSE: wondering if 7.6.120.0 code will work. Currently we are running 7.4.100.0 and are holding off upgrading due to PI requirements.
Any help is appreciated.
Dan
Solved! Go to Solution.
05-09-2014 02:55 AM
I think answer can be found here:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148422
Prime Infrastructure 2.1 allows you to manage Cisco WLC Releases 7.5.102.0 and 7.6.x with the features of Cisco WLC 7.4.121.0 and earlier releases. Prime Infrastructure 2.1 does not support any features that are introduced in Cisco WLC Releases 7.5.102.0 and 7.6.x except the new access point platforms and the new mobility feature.
Pavel
05-09-2014 02:55 AM
Pavel
