pix limited bandwith
jaymare33
I hope this is the right place where I can post my problem: I just want to limit traffic on my pix's ethernet interface.. is it possible?
in the same document you find a section entitled "Activating the Service Policy", where you find the command:
hostname(config)# service-policy qos interface outside
One service policy can be applied per interface.
A sample configuration to limit all traffic across an interface, which should be close to what you need:
hostname(config)# policy-map Limit1MB
hostname(config-pmap-c)# class class-default
hostname(config-pmap-c)# police output 1000000 37500
hostname(config)# service-policy Limit1MB interface outside
You can also use other interfaces and apply the service-policy.
Hope this helps! Please rate all posts.
Regards, Martin
mheusinger
Level 10
Level 10
with version 7.0 QoS is part of the PIX features. This includes rat limiting. For a detailed explanation of possibilities and limitations please read in the "Cisco Security Appliance Command Line Configuration Guide, Version 7.0" the section on rate limiting: "Applying Rate Limiting"
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080450b9a.html#wp1045477
Regards, Martin
thank you! that seems to be really helpfull.. however I could not find a way to apply qos to an ethernet interface. T-T
Regards, Martin
thank you.. it has been really helpful!
