Please help me confirm if ciscoview 6.1.5 support router such as cisco 2801
cn1by080byj
Mini-RMON is typically only supported on switches, yes.
5 Replies 5
Joe Clarke
Absolutely. The 2801 is supported. The package that supports it is the Rtr2800 package. The latest version of the package is 8.0.
Thanks so much!
now we have the router type include:
2691,3825,2621,2801,2651,
Would you please help me confirm if all of them support the rmon and we only need enable rmon function in router then we can setup variable such as "CRC""collision""jabber"etc.
All of these devices support RMON events and alarms, but that's it. You will not be able to do RMON etherstats on these devices. You will also not be able to use the CiscoView Mini-RMON Manager with these devices (but the CiscoView device view will work).
Thanks again!.
Would you please tell me why these devices can not support RMON only switch not router?
