Pls help configure ISC VPN layer 2 in MAN
I can configure VPN layer 3 between 2 customer sites by using ISC, but when configuring VPN layer 2 between 2 customer sites, the error appears:
"Service Request Details for Job ID 67
Attribute Value
Type L2VPN
State INVALID
Operation Type MODIFY
Service Request ID 70
Last Modification Time Thu Jan 12 12:20:25 CST 2006
Customer Pepsi
VPN ERS_VPN_PEPSI
L2Vpn Policy PEPSI_ERS
L2Vpn ServiceType EthernetEVCS
L2Vpn Core Type MPLS
EndToEndWire ID 25
Status Message [ R7609-BTQ-NPE-01 ] Provisioning Failures,[layer 3 sub interface exists for this port. To proceed, delete the sub interface first.] }
[ CISCO_COKE ] Successful Deployment
[ C3750-TXU-UPE-01 ] Successful Deployment
[ C3750-HBT-UPE-01 ] Successful Deployment
[ R7609-HBT-NPE-01 ] Provisioning Failures,[layer 3 sub interface exists for this port. To proceed, delete the sub interface first.] }
[ SPARE ] Successful Deployment
State INVALID
VC ID 800
Attachment Circuit ID 101
PE Name R7609-HBT-NPE-01
PE Interface GigabitEthernet2/2.950
CE Name CISCO_COKE
CE Interface GigabitEthernet0/1.950
VLAN ID 950
Attachment Circuit ID 100
PE Name R7609-BTQ-NPE-01
CE Name SPARE
CE Interface FastEthernet1/0/1.950
VLAN ID 950 "
Pls help me to figure out the problem.
Brian
Re: Pls help configure ISC VPN layer 2 in MAN
The message:
"[ R7609-HBT-NPE-01 ] Provisioning Failures,[layer 3 sub interface exists for this port. To proceed, delete the sub interface first.]"
gives a hint on what could cause this.
The error mentioned refers to a setup failure, which occurs, when you have an IP address configured on the interface to be used for L2VPN/EoMPLS. In a sense it is a security measure not to kill an IP service in place somewhere by setting up L2transport.
Can you check the config of interface GigabitEthernet2/2.950 in your 7609? One prerequisite of EoMPLS is to remove all IP addresses.
Hope this helps! Please rate all posts.
Regards, Martin
I am work togetther with Brain, I done following your instruction but error is the same.
File enclose is command is genarated by the ISC when resquest sevices L2vpn.
Flaform: ROUTER 7609, IOS Ver 122.2(18) SXD3
ISC 4.0
please help to resquest l2vpn for MAN netwoek?
can you telnet to the router and perform a "show run Interface GigabitEthernet2/2.950" and let me see the output? The configuration created looks fine. Are there IP addresses found on the Interface GigabitEthernet2/2?
I still assume there is already some configuration in place preventing the application of the additional EoMPLS config.
What you also can do is to apply the configlet manually line by line to see, when the error occurs.
Regards, Martin
Helo Martin,
The subInterface GigabitEthernet2/2.950 is not exits in router. I don't known why.
I send your configration file of Router 7609, please have look it and help me find out problem
Thank you,
Thuong
132
