Pls Suggest
Dear All,
Please find the output of my router. I'd tried to implement some QOS to my router. But after implementing the same I found that the serial interface's available Bandwidth is showing 8 kilobits/sec only.
Also my target is to putting best value for ABC_ACL data. Next DEF_ACL data and then GHI_ACL data. Find the attachment for mote details.
Please suggest how can I put all this required traffic to a QOS.
Thanks & Rgds
Go San
1 ACCEPTED SOLUTION
Re: Pls Suggest
Your QoS config looks fine.
A quick math check will show exactly how much bandwidth in kbps that you're allocating for each class as shown in ( ).
Your line speed is set at 64 kbps, and the total allocated bw is 57.6 kbps. The remaining 8 kbps that you see when you issue "show int" is for your class class-default.
policy-map S_D
class ABC
bandwidth percent 70 (44.8 kbps)
class DEF
bandwidth percent 10 (6.4 kbps)
class GHI
bandwidth percent 10 (6.4 kpbs)
class class-default
fair-queue
hth,
hieu
Re: Pls Suggest
policy-map S_D
class ABC
class DEF
class GHI
class class-default
fair-queue
hth,
hieu
Re: Pls Suggest
Hi, Hiue,
Thanks for your reply.Please guide me,in real world scenario - which is the best to choose match-any or match-all?
go san
Re: Pls Suggest
it's best that you use "match-any" so that any parameter specified in your particular class can be matched.
hieu
Re: Pls Suggest
hi hieu,
thanks
144
