11-21-2005 08:56 AM
I'm using LMS 2.5 (Ciscoview 6.1). I can't find how to see the POE configuration of the ports with CiscoView on Catalysts 6000. Is it possible?
11-21-2005 10:46 AM
It should be - if you have the lastest package support files (version 7.1 appears to be current) for the Catalyst 6000 loaded into CiscoView. See http://www.cisco.com/cgi-bin/Software/CiscoView/cvresult.cgi?product_class=Catalyst+Switches&product=Catalyst+6000&application=CiscoView+6.1 to download. the readme indicates that the WS-X6148-RJ45V etc. are supported with that release.
Remember that, when keeping CW up to date, one needs to updates Common Services, RME, Campus Manager, and CiscoView package support all separately.
11-22-2005 04:51 AM
Now I have updated my packages and I still don't find where is the POE information (what menu on a port: configure/physical ? Other ?)
These are I think the most important informations of my package map :
22. Cat6000 7.1 Cat6000 Package
23. Cat6000IOS 19.1 Cat6000IOS Package
26. CatQdm 1.9 Catalyst QoS Device Manager for Catalyst 6000 Devices running CatOS
28. CLIParser 1.4 CLI Parser Package
