Webcast-Catalyst9k
policy map not show results in Cat6500
                   I have configured QoS in Catalyst 6513 for telepresence service and when I do "show policy interface gix/y" don't show the traffic is being marked.
I think that the QoS is marked the traffic correctly because I am sawing packets marked with AF41 in the next hop for that suspect that the problem is in the "show comand".
It´s normal this behaviour or it could be a IOS bug?
This is the configuration:
ip access-list extended ACLtelepresencia_in
permit ip any any
class-map match-any telepresencia
  match access-group name ACLtelepresencia_in
policy-map telepresencia_in
  class telepresencia
   set dscp af41
D08MNSSRS0#sh policy-map interface  GigabitEthernet3/13
GigabitEthernet3/13
  Service-policy input: telepresencia_in
    Class-map: telepresencia (match-any)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: access-group name ACLtelepresencia_in
        0 packets, 0 bytes
        30 second rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
Alberto
Everyone's tags (6)
197
