Populating Devices in Topology Groups in Campus Manager/Topology Services
Hello All:
For some reason, when I go into Topology Services in Campus Manager, the default network views are populated with discovered devices, but when I go into topology groups, all the default groups (i.e. CS, RMS, Campus) show zero devices. There are devices setup in the DCR, so my assumption is those corresponding devices should show up here, too.
Is there something I am missing here? Is there some way I should be manually populating these groups?
I'm running Campus Manager 4.0.4 on LMS 2.5
Thanks.
Silver
Re: Populating Devices in Topology Groups in Campus Manager/Topo
You may need to drill down into these groups before you will see any devices
Cheers,
Michel
When I drill down I still don't see any devices.
121
