port channel
what's a port channel.is it a multilink of physical interfaces..
1 REPLY
Re: port channel
Hi!
Yes port channel is a method by which you can aggregate ports so that in theory the combined bandwidth of the port is the sum of the individual port's bandwidth. These ports then act like a single logical link.You need to do these to configure a port channel:
- configure the physical interface
- configure the port channel group
- configure the vlan
Its also called as EtherChannel link.
For more details please refer the following link -->
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007f2c6.html
Hope this helps.
Please rate all helpful posts.
AbhisheK
652
