Webcast-Catalyst9k
Port Management sollution
We have come to a point that we think it is necessary to delegate some easy network management tasks to our helpdesk, like:
* Setting access port vlan
* Clearing learned macaddresses from a user port
* Setting speed/duplex settings for an access port
etc, without having other privileges. So basically we need a product that can give us rolebased configuration access.
Does anyone know a software sollution that allows us to do this?
1 REPLY
Re: Port Management sollution
Using Smartports in the Web Device Manager or Network Assistant looked like a good way to do it, but unfortunatly it seems that custom Smartport macro's cant be used in the Web Device Manager... Which makes it useless for us.
127
