Port utilization
ghenaprocop
Can anyone tell me if I can see my port utilization on all my switches 2950 and 2970, without configuring the snmp agent on switches? I want to see the utilization in percents % or in Mbytes, somthenog like that.
If it is not possible without SNMP, than can you recomend a good software that will monitor the port utilization via SNMP?
nhabib
Level 9
Level 9
The cheapest (free) and most popular solution would be MRTG (it uses SNMP):
http://www.mrtg.org
Thanks, I will try!
Regarding "free" software - remember the acquisition cost may be free but ownership isn't.
The time and effort you expend making any solution work in your environment usually far outstrips the cost of a license for a commercial solution that -may- have much less tweaking required.
So, free software that requires X hours to set up may cost more than software you buy that requires X/n hours to set up.
Look at Solarwinds for a entry/mid range management suite.
Hope this helps. Please rate helpful posts.
