Community Member
Portlet Query
Hi All,
How to add the portlet WCS in LMS.
Attached the screenshot for reference..
Rgds,
Sub.
1 ACCEPTED SOLUTION
Re: Portlet Query
You need to add a new iFrame portlet.  Then, configure the iFrame to point to the URL of your WCS box.  The iFrame portlet can be found under the Miscellaneous section of the Add Portlet interface.
Re: Portlet Query
Community Member
Re: Portlet Query
Hi Joe,
Thanks for the solution..
Attached diagram,which Layout is using, I tried with  layout . But iam not getting exact cisco Unified Network View on the LMSPortal.
Kindly advice..
Rgds,
Sub
Re: Portlet Query
I'm not sure what layout is being used.  I did not build that server.  It looks like either a 2 column (70,30) layout or possible 1-2, 1 (70,30).
199
