Prime 2.1 Assurance Help
Hopefully this is the correct forum for our question...
We were running ManageWise Netflow Monitor with the following configuration on our 7606 to monitor traffic flow:
ip flow-cache timeout active 1
interface TenGigabitEthernet4/8.2570
description ATT ASE - Homan - Pri
encapsulation dot1Q 2570
ip address 10.0.22.49 255.255.255.248
ip access-group TEMP-CORE_LOCKDOWN in
ip flow ingress
mls netflow sampling
interface TenGigabitEthernet4/8.2581
description ATT ASE - Jackson - Bkup
encapsulation dot1Q 2581
ip address 10.0.22.57 255.255.255.248
ip flow ingress
delay 120
ip flow-export source Loopback1
ip flow-export version 5
ip flow-export destination 10.223.241.129 9996
Now we want to use Cisco Prime 2.1 Assurance.  Is it a matter of changing the following ip address and port (below)?
ip flow-export destination 10.223.241.129 9996 -- ManageWise Netflow Monitor
--to--
Ip flow-export destination 10.223.251.250 9991  -- Cisco Prime
Also, what is needed to display the traffic flow information?
Hall of Fame Super Silver
That's the gist of it on the
That's the gist of it on the collector side.
On the Prime Infrastructure side, please see the following video on demand that Cisco has posted walking through the setup and use of the Assurance feature:
  https://www.youtube.com/watch?v=pCgkq1S01xk
Thank you for the information
Thank you for the information to setup Assurance.
Using ManageWise Netfolw we were able to display the following information for a specific site:
Traffic In - Total - Max - Min - Ave
Traffic Out - Total - Max - Min - Ave
Can we do this using Prime?  If so, what do we need to do?
46
