05-19-2012 06:39 AM
When the installation begins you will ask a series of data and finally the machine is restarted and is asking for login. I think that there should LMS to access the web if I'm http://ip.address:1741 access is do not open any page.
What should I do?
Jose Luis Diaz Ortega
Ing de Sistemas.
Administrador de redes.
05-19-2012 09:00 PM
You mean the linux OVA image in VMWare is installed and than web access is not successful? What does the page shows when tried? Any screenshot will be helpful. To see if the installation is successful or not a pdshow output from NMSROOT/bin/pdshow.
Can you also try https://
-Thanks
05-22-2012 08:46 AM
Thanks for the reply.
I refer to the image. ISO in linux install in a VMWare virtual machine, but I try to make access to the website but I have no success. The browser shows me a message saying "the connection has expired"
Ing de Sistemas.
05-22-2012 11:04 PM
well since you can connect and issue show running, i guees the server is up and running.
what is the CLI output of pdshow ? as pr other posts ...
can you connect via httpS ?
I suspect external reason for why you can not conenct, like maybe firewall blocking, or reject of Cert in browser.
what browser are you using, and did you tri an other brand ?
Martin
05-22-2012 12:59 PM
The runnining-config has the following configuration:
hostname netadmin
ip domain-name test.com
interface GigabitEthernet 0
ip address 192.168.1.39 255.255.255.0
ipv6 address autoconfig
ip name-server 192.168.1.13
ip default-gateway 192.168.1.15
clock timezone UTC
ntp server 192.168.1.13
username sysadmin password hash $1$AXbfgdfr34dfdrFpuTMpX3yelYd3gu1 role admin
service sshd
password-policy
lower-case-required
upper-case-required
digit-required
no-username
disable-cisco-passwords
min-password-length 6
logging localhost
logging loglevel 6
icmp echo on
Ing de Sistemas.
05-22-2012 11:11 PM
please verify that your gateway is running, and you have basic connectivity, like you are able to ping from client PC to the server and from the server are able to ping your gateway.
(Reason is that the email sent to me when subscriping to this post, contains different gateway accoring to the IP subnet posted here - guess the post is editted or its lost in translation)
05-21-2012 05:17 AM
in VM-Ware vsphere client, or other admintool you might use; PowerON the Appliance.
wait.
retry the access to the webpage
05-25-2012 03:45 PM
If indeed the gateway is correct and if I respond to ping from the workstation I am trying to connect.
If I have the application installed on a VMWare
Ing de Sistemas.
05-26-2012 12:20 PM
It is imp. to see if the processes work fine. Please post show /opt/CSCOpx/bin pdshow ouput.
-Thanks
Vinod
06-01-2012 04:13 AM
Hello Jose Luis,
Is it working now ?
If not, perhaps you can try this:
https://supportforums.cisco.com/message/3615473#3615473
Patrice
