You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Prime Infrastructure 1.3
I've come across the following error when trying to deploy configuration tasks to two WiSM 2 controllers
"Config Deploy"-jobs fail with the message "Failed In CA backup before deploy".
We have tried changing management user accounts, passwords but the problem remains. All other aspects of the software seems to be working.
Controllers are on 7.4.110
Anyone else come across it?
Mat
  • Network Management
Re: Prime Infrastructure 1.3
Hi ,
Seems to be this BUG, However I would suggest you to check the issue with new customer wIPS profile. It could be a premission issue as well.
CSCuh78622    Day1: Wireless- job failed- Failed In CA backup before deploy
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I'm not able to see all the details on the bug but i've signed up for any updates.
It says:
Insufficient Permissions to View Bug
This bug contains proprietary information and is not yet publicly available.
You may find useful information within theCisco Support Community
It's an Internal Bug ,BUG is not fixed yet
206
