Prime Infrastructure 2.0 and Nexus 5548, SSH credentials fail
slindkvist
I'm having problem getting the Prime Infrastructure 2.0 to login with SSH to a Nexus 5548 to do an inventory. I get "Wrong Telnet/SSH credentials". But when I use the same credentials from another SSH-client it works fine. I also tested to SSH from the console of the Prime-server and that also works fine.
Any ideas???
Stefan Lindkvist
Marvin Rhoads
I have PI 2.0 working against Nexus 5k's in two different installations. See below for an example (click to enlarge).
Have you put in an entry in both the login and enable fields (even though they are not separately required when logging in directly)?
Hi Marvin,
Yes, we put the same password in the enable field as in the user/password field. Still no luck...
