Community Member
Prime Infrastructure 2.0 Collection Failure for WLC 5508
We have installed prime infrastructure 2.0 as a VM.
I added 2 WLCs (AIR-CT5508) in the device work center.
Both the WLCs are showing as "Managed" but under the collection status it says "Collection Failure".
When I hover over the message it reads:
Other Error: Wireless Controller added successfully but some tables had their records dropped as their key fields failed validation"
Any ideas?
Satyaki
1 REPLY
Hi Satyaki, Try to reboot the
Hi Satyaki,
Try to reboot the WLC ,if possible and then check the status of the issue.
Regards-
Afroz
**Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
415
