Community Member
Prime Infrastructure 2.0 top cpu utilization
                  We've recently installed PI2.0 and it is working well, with a small exception - the top cpu utilization only shows the wireless controllers.  is there a setting to adjust that to all devices or has anyone worked in a fix ?
thanks for your support.
1 ACCEPTED SOLUTION
Re: Prime Infrastructure 2.0 top cpu utilization
Hi ,
check the attched screen shot and look for the same settings..
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi ,
Thanks-
Afroz
Community Member
SWEET - Thank you very much :-)
Community Member
...it had potential, however the only thing to display are the wireless controllers.  ALL was selected and it onlyu displays the WCs.  What say you ?
Hall of Fame Super Silver
My Prime 2.0 shows my switches along with the WLC when configured per Afroz's suggestion.
Community Member
Thanks - it should be that simple - it actually had until the server was reloaded, all services are up.  I'll speak with TAC
244
