prime infrastructure 2.1 create file in flash
I am trying to figure out a way to create a file in flash on a router during a plug and play deployment.  What I want to do is be able to create a CLI template that i can create a custom TCL script and use that as part of a composite template deployment.
So in the end i would like to have this happen to new routers.
Router is plugged in
Router gets CNS config and has IOS upgraded
Router then gets the first template pushed which creates the TCL script
Router then gets the second template that has the full configuration as well as an EEM app that as part of that will run the TCL script
22
