Webcast-Catalyst9k
Prime Infrastructure 2.1 Home Page
When I log into PI2.1, the page that opens first is
>Administration > System Settings > Configuration Archive
I would prefer the actual Home page is loaded first but I cannot find a setting for me to configure this.  Does anyone know where I can find this?  TIA
1 REPLY
Have you checked your
Have you checked your bookmark to Prime Infrastructure? If you bookmark PI on a specific page it will direct you to log in if you're not already but after the login the page linked to will still load (in this case the Configuration Archive settings page).
To test this, log off of PI and remove everything but the IP or hostname of your server in the address bar and log in from there.
PI should always direct you to the home Dashboard page unless a direct link is used.
37
