08-08-2017 06:10 AM
Dear All;
I was deploying Prime Infrastructure 3.1, license has been installed, I was trying to add the following PIDs of nexus switches: C93108TC-EX, C9272Q, C92160YC-X. Unfortunately these devices appears as Unsupported device type.
When I've checked Cisco Prime Infrastructure 3.1 Supported Devices I didn't find these devices in the supported matrix even in prime 3.2.
So anybody have an idea about this or what should I do in this case?
Solved! Go to Solution.
08-08-2017 07:53 AM
its still not supported yet , Cisco dropped the ball a bit on this , lot people raising same issue
https://supportforums.cisco.com/discussion/13224836/nexus-93180yc-ex-vs-prime-infrastructure-314-device-pack-7
08-08-2017 07:53 AM
08-28-2017 02:39 AM
