Prime Infrastructure and WLAN Configuration Controller Templates
I work with PI v1.2 in customer environment. This app has SNMP relation with 7 controllers (4 controllers in 2 WiSM modules, 3 controllers are standalone). All controllers uses WLANs which I sometimes need to update. I would like to use the PI so that update all of them in one step. But when I use WLAN Configuration Controller Templates and choose given WLAN Template then the PI answer me with error message: "Unknown Exception Occured. If the problem persists send logs to the Tech Support."
Have you anyone had such a problem? Is it any bug of the application?
Thank you.
224
