01-14-2014 02:26 AM
I have question regarding the port groups.
Is it possible to create a port group based on port type where the port type is a dot1q trunk?
In the drop down menu, I can only find Cisco ISL.
My goal is to apply the interface/port monitoring only on trunk interfaces/ports.
Joerg
01-14-2014 02:55 AM
This discussion will be of your help:
https://supportforums.cisco.com/thread/2239478
You can select the interfaces of your interest for port groups manually. Check the user guide here:
P.S : In CSC it is always good to share the device and Cisco PI platform and version details. Many times you'll find features are supported in one release and not in others.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
01-14-2014 03:01 AM
Hi Vinod,
Thanks for your answer.
It is PI 1.4
But is there no possibilty to filter for trunk/dot1q ports?
Because selecting them manually could be a lot of work in a large deployment.
Joerg
01-05-2015 07:00 AM
Hi Vinod
In LMS 4.2 only trunk ports were monitored by default as it was safely assumed that this is what most people would want to do as a minimum.
It seems absurd that this new monitoring functionality in PI 2.2 cannot achieve this simple task without manually adding each interface in. I can tell you that this is not at all practical with our network of 700+ devices. Surely there is a way to identify a dot1q trunk?
Cheers
Paul
Cisco Prime LMS 4.2.5
Prime Infrastructure 2.2
