Prime LMS 4.2.1 Topology Issue
I have a problem with the Topology,
when i'm entering Monitor --> Topology Services i get an error message,
the browser that im using is IE 8,
I attached Two files:
First attempt Pic' - I tried it with the the CW Server Hostname.
Seconed attempt Pic' - I tried it with the CW Server IP.
the outpot was the same
The things that i've try are:
1. I deleted the cookies from the browser
2. cleaned the cache
3, cleaned the cache of the JAVA.
4. remove the JAVA and give to CW reinstall it.
5. Last attempt I did was to restart the server.
nothing of the above didnt help.
Please advice,
Thanks.
P.S
I'm attacing two more files:
1. pdshow
2. java -version
Message was edited by: Dawit Zeru
Everyone's tags (5)
Those three files should be copied successfuly to your Java endorsed directory ($Java\jre6\lib\endorsed). Peae check if they exist there, and give them a full permission to be executed.
Mae sure your hostname is fully DNS resolvable, if not please make an entry in /etc/hosts file.
Re-run the topology and check how it goes.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vindo,
i attached two more files to the Q.
about the host file i' will check it,
and i will gwt back to you
thanks
Re: Prime LMS 4.2.1 Topology Issue
I believe I have seen this before. You need to right click on Internet Explorer icon and run as Administrator then try what you are needing to do.
Worked for me.
731
