Prime LMS 4.2.3 Device Discovery Not Finding New Devices
Can somebody assist me please, I'm not able to discover any new devices in our LAN when running a discovery, either in Standard or Custom mode.  Below is the recent output from csdiscovery.log but I'm not sure how to interpret it for likely solutions, any help most gratefully received.
[ Thu Nov 07 16:59:12 GMT 2013 ] FATAL  [CSDiscoveryAdaptor : putAllProcessed]  : [PUTALL] FINAL CALL end at:1383843552830
[ Thu Nov 07 16:59:13 GMT 2013 ] FATAL  [CSDiscoveryManager : stopDiscovery]  : URN_NOT_FOUND : urn "CSDiscovery" : Not found !!
com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "CSDiscovery" : Not found !!
at com.cisco.nm.xms.ctm.client.CTMCall.establishIPC(CTMCall.java:245)
at com.cisco.nm.xms.ctm.client.CTMCall.invoke(CTMCall.java:409)
at com.cisco.nm.xms.ctm.client.CTMCall.setMethodAndInvoke(CTMCall.java:456)
at com.cisco.nm.xms.ctm.client.CTMClientProxy.invoke(CTMClientProxy.java:70)
at $Proxy553.stopDiscovery(Unknown Source)
at com.cisco.nm.csdiscovery.CSDiscoveryManager.stopDiscovery(CSDiscoveryManager.java:96)
at com.cisco.nm.csdiscovery.ui.action.DiscoveryTypicalAction.perform(DiscoveryTypicalAction.java:496)
at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:291)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Thread.java:662)
log4j:WARN No appenders could be found for logger (com.cisco.nm.csdiscovery.CSDiscoveryManager).
log4j:WARN Please initialize the log4j system properly.
java.io.FileNotFoundException: C:\Program%20Files\CSCOpx\MDC\tomcat\webapps\cwhp\WEB-INF\lib\discovery.jar (The system cannot find the path specified)
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:127)
at java.util.jar.JarFile.<init>(JarFile.java:135)
at java.util.jar.JarFile.<init>(JarFile.java:72)
at com.cisco.nm.discovery.log.NgdLogger.init(NgdLogger.java:59)
at com.cisco.nm.discovery.log.NgdLogger.<init>(NgdLogger.java:39)
at com.cisco.nm.discovery.log.NgdLogger.getInstance(NgdLogger.java:49)
at com.cisco.nm.discovery.log.LogWrapper.<init>(LogWrapper.java:13)
at com.cisco.nm.discovery.log.LogWrapper.getInstance(LogWrapper.java:22)
at com.cisco.nm.discovery.framework.DiscoveryManager.<init>(DiscoveryManager.java:60)
at com.cisco.nm.csdiscovery.DiscoveryStatusMain.<init>(DiscoveryStatusMain.java:18)
at com.cisco.nm.csdiscovery.util.DiscoveryUtil.publishURN(DiscoveryUtil.java:2000)
at com.cisco.nm.csdiscovery.CSDiscoveryManager.startDiscovery(CSDiscoveryManager.java:67)
at com.cisco.nm.csdiscovery.CSDiscoveryManager.main(CSDiscoveryManager.java:151)
[ Thu Nov 07 21:34:19 GMT 2013 ] FATAL  [CSDiscoveryAdaptor : putAllProcessed]  : [PUTALL] FINAL CALL end at:1383860059330
1 REPLY
Hi Dave,
Hi Dave,
Can you advise, if you were able to solve the above issue ?
Sabine
606
