Prime LMS 4.2 integration with ACS 4.1 Authorization problem
Dears,
We have done the tacacs configurations on the prime LMS and users are authenticating successfully, but we are facing the problem with the authorization as users cannot do anything.
I know that we need to import the role list to the ACS, but I am not sure from where we can get it.
Please advise.
Reagrds
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
1 ACCEPTED SOLUTION
HI ,
LMS 4.0 no longer integrates with ACS the way that LMS 3.x did.  You  can still use ACS for authentication in LMS 4.0, but for authorization,  each user must have a local account in LMS, and the roles will be  assigned using LMS 4.0's new RBAC.  Users are defined under Admin >  System > User Management > Local User Setup, and roles are defined  under Admin > System > User Management > Role Management  Setup.
By default, if a user does not have an account in LMS, they will receive the Help Desk role
Please check the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/admin/security.html#wp1100379
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
HI ,
Thanks-
Afroz
Hall of Fame Super Silver
Like Afroz says, LMS 4.x significantly changed the ACS integration model. It's now authentication only. All LMS Authorization is handled by the RBAC functionality built into LMS itself.
395
