Prime LMS 4.2 to save devices configurations "copy run start"
Anas Hijjawi
we need to create a job on LMS to save the configurations on the network devices, like everyday LMS should run "copy run start" on all the devices.
Any one can assist, thanks
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
Vinod Arya
You can create a NetConfig job using LMS, which can do this for all LMS managed devices. You can simple select an Adhoc job and use command copy run start and schedule as per you requirement.
Check more details here on NetConfig.
Also, You can generate an Out-of-Sync report for the group of devices for which running configurations are not synchronized with the startup configuration from :
From here you can directly sync the devices which will do the same task of doing copy run start. Unfortunately, it cannot be scheduled and hence needs to be checked manually usually.
Check details on Out-of-Sync here.
-Thanks
Vinod
**Encourage Contributors. RATE them**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
