Problem in the integration of CWLMS with the ACS
Performing the integration of CWLMS 3.0 with the ACS 4.1 appliance, access to the portal be very slow, the integration was sucesfull and the modules operate correctly.. the problem is the slowness..
Reviewing the traffic between them i found that CWLMS try netbios connections with the ACS.. many of them .. and that delay .. i think..
I think that there is the problem..
Sorry for the english..
Any idea?
1 ACCEPTED SOLUTION
Re: Problem in the integration of CWLMS with the ACS
If LMS is running on Windows, add an entry for the ACS server into the LMS server's local hosts file. For example:
10.1.1.1 acs
10.1.1.1 acs
Thanks, it works!
99
