problem with cm 5.0.2
hi,
I have installed CW LMS3.0 with Dec2007 updates and CM now get devices from DCR. I have 500 managed devices but CM only discover 42 and altough in DCR is discovered ok in CM the 42 devices appears as unreachable.
Re: problem with cm 5.0.2
This could be a recent bug that was discovered in Campus Manager. First, check you do not have any Data Collection filters defined in Campus Manager, then enable frontend, framework, core, and corex Data Collection debugging, run a new Campus Manager Data Collection, then post the ani.log.
Here you are the ani.log.
I don't have any filters defined. The install is new and clean
118
