10-13-2008 10:38 PM
I installed one month ago a LMS v3.0.1 and all goes fine during 2 weeks. Now I encounter an error with CTMJrmServer process.
Here is the CTMJrmServer.log :
CTMJrmServer: initializing daemon manager
CTMJrmServer: initialized daemon manager
[ Mon Oct 06 11:07:58 WAT 2008 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for jrmw-log
[ Mon Oct 06 11:07:58 WAT 2008 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as jrmw-log-RMELogLevelChange
[ Mon Oct 06 11:09:24 WAT 2008 ],FATAL,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,139,getJRM:Can't bind to JrmServiceManager. giving up and exiting.
[ Mon Oct 06 11:09:24 WAT 2008 ],ERROR,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,<init>,66,Null JRM. Exiting
I look at some topics related to CTMJrmServer but I haven't find a solution.
For info : I haven't change the server name. I look at registry but I don't see anything wrong.
Thanks for your help !
Florian
Solved! Go to Solution.
10-23-2008 08:28 AM
You have modified the service startup parameters. This has broken LMS. You must revert all CiscoWorks, DFM, and CWCS services EXCEPT CiscoWorks Daemon Manager, CWCS rsh, syslog, and tftp services to Manual, then reboot. After this, things should work again.
10-14-2008 08:25 AM
Please post the output of the pdshow command.
10-14-2008 08:52 AM
10-14-2008 09:20 AM
Please send the output of the command:
pdreg -l CTMJrmServer
And the output of the DOS SET command.
10-14-2008 09:38 AM
10-14-2008 09:47 AM
Enable CTMJrmServer debugging under RME > Admin > System Preferences > Application Loglevel Settings, then try starting CTMJrmServer. Then post the CTMJrmServer.log.
10-20-2008 11:55 PM
10-21-2008 09:16 AM
Please post the jrm.log.
10-22-2008 01:31 AM
10-22-2008 08:58 AM
Please post the service startup parameters from the Services control panel.
10-23-2008 08:23 AM
10-23-2008 08:28 AM
