02-14-2008 11:14 PM
Hi all,
I am new (just not more than 3months) to CW but actively read the DFM user manual.
Recently I follow up integrity problem with the DFM tables where some devices are 'questioned' and can't be discovered and all their DCR entries are gone.
Two of them I'm working on have the following issues.
1. one DFM entry is always in 'questioned' status. i tried to delete it by turning off the sync but it's still inside the DFM. i can rediscover it but gonna delete it as we gonna make changes to the device's hostname.
2. another DFM entry was with the old domain name (somehow the DNS was migrated before I was there). It no longer be resolvable from the DNS server and hence failed for any rediscovery process. I tried to delete it and it went into the 'questioned' status again.
I tried to create new DCR entries and enabled the sync between DCR and DFM. The DFM entries still remain after I deleted them in DCR. It seems the two databases use different fields to establish the relationship.
Anything I can do to get them off without DFM reinitialization?
Steven
02-15-2008 09:38 AM
What version of DFM is this? If you go to Devices > Rediscover/Delete, what is the reason this one device is in a questioned state?
If you delete devices from DCR, they should be deleted from DFM. However, as you pointed out these are two separate databases which rely on inter-process communication to keep things in sync. However, you should be able to manually delete devices out of DFM. A deleted device would only go back to questioned if it was still in DCR, and you had auto-sync enabled.
02-18-2008 11:24 PM
The DFM version is 3.0.2.
The DCR entry is gone after I deleted it last week but the DFM entry still exists although sync is enabled. The DFM entry is under "questioned> SNMP timeout" with error code "Snmp Timeout".
It is not the first object or instance I failed to delete it from both DCR and DFM when the sync is enabled through "Auto Import Filter".
I had disabled the 'Sync' and then deleted it but it still exists with 'pending' status in the DFM. I just tried again and it's the same. The discovery progress stops at 10% for more than 10mins. Error code is again 'Snmp Timeout'.
02-18-2008 11:27 PM
I've seen this before. Once in the pending state, run the following commands:
pdterm InventoryCollector Interactor InventoryCollector1 Interactor1
pdexec InventoryCollector Interactor InventoryCollector1 Interactor1
The device should then be gone from DFM.
02-19-2008 12:16 AM
I tried these command set with both sync enabled and disabled. Both couldn't get the device gone. The device remains in the pending status.
02-19-2008 08:14 AM
Then try a full dmgtd restart instead.
02-19-2008 05:37 PM
I did and the device still remains in the pending device list.
02-19-2008 06:37 PM
Is this on Windows? If so, do you see any errors in the Event Viewer?
02-19-2008 10:19 PM
Oh yes. I found the following happened on 31-Jan and 7-Feb.
Event Type: Error
Event Source: SideBySide
Event Category: None
Event ID: 32
Date: 31-Jan-08
Time: 16:11:30
User: N/A
Computer: PC
Description:
Dependent Assembly Microsoft.VC80.MFCLOC could not be found and Last Error was The referenced assembly is not installed on your system.
Event Type: Error
Event ID: 59
Date: 31-Jan-08
Time: 16:11:30
User: N/A
Computer: PC
Description:
Resolve Partial Assembly failed for Microsoft.VC80.MFCLOC. Reference error message: The referenced assembly is not installed on your system.
Event Type: Error
Event ID: 59
Date: 31-Jan-08
Time: 16:11:30
User: N/A
Computer: PC
Description:
Generate Activation Context failed for D:\PROGRA~1\CSCOpx\lib\vbroker\bin\MFC80.DLL. Reference error message: The referenced assembly is not installed on your system.
Event Type: Error
Event ID: 32
Date: 31-Jan-08
Time: 16:26:48
User: N/A
Computer: PC
Description:
02-19-2008 10:46 PM
This is due to bugs CSCsm69242 and CSCsm76320. We do not have a workaround yet, but we are working to find a solution. You can either watch these bugs using Bug Toolkit on Cisco.com, or open a TAC service request.
02-19-2008 11:26 PM
One thing you could provide that could help us is the version of the DLLs msvcm80.dll, msvcp80.dll, and msvcr80.dll installed on this system. Search your entire computer for all instances, then right-click on them, select Properties, and select the Version tab. We are interested in the File Version from each DLL. Thanks.
02-20-2008 12:14 AM
Here you are.
[Path for msvcm80.dll, msvcp80.dll, msvcr80.dll, their version]
C:\WINDOWS\WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb, 8.0.50727.163
C:\WINDOWS\WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd, 8.0.50727.42
C:\WINDOWS\WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700, 8.0.50727.762
C:\Program Files\McAfee\Common Framwork\Microsoft.VC80.CRT, 8.0.50727.42
D:\tsm_images\TSM_BA_Client\Windows\system32, 8.0.50727.762
D:\Program Files\CSCOpx\lib\vbroker\bin, 8.0.50727.42
D:\Program Files\CSCOpx\objects\smarts\bin, 8.0.50727.42
D:\Program Files\CSCOpx\objects\smarts\lib, 8.0.50727.42
D:\tsm_images\TSM_BA_Client\Windows\winsxs\92rg91xw.1p4, 8.0.50727.762
D:\tsm_images\TSM_BA_Client\Windows\winsxs\b2rg91xw.1p4, 8.0.50727.762
D:\Program Files\CSCOpx\objects\smarts\bin\system, 8.0.50727.42
02-20-2008 08:48 AM
Thanks for this. It appears you have the TSM backup software loaded on this server. Can you temporarily remove that software, reboot, and see if DFM starts to work again for you?
02-20-2008 07:46 PM
Thanks for your suggestion and I get to check with my team mates first. Anyways, appreciate for your quick reply.
02-19-2008 01:27 AM
I figured out that the process "DFMCTMStartup" is shut down. Does it matter?
