Webcast-Catalyst9k
Blue
Problem with IPM installer doing "whoami"
I forgot to bring up this issue that I had run into before with IPM 2.5. I'm upgrading to LMS 2.6 using a non-root user account, but with uid 0. This works fine installing the original LMS pieces (CS, RME, CM, etc.) However, the IPM 2.6 install script apparently performs a "whoami" (same as IPM 2.5) that catches the fact I'm not the 100% legit "root". Is there any workaround for this, or do I need to open a TAC case and get a bug filed? There's no way I'll be given the root accout password.
ERROR: ipm script must be run as root for this option.
Cannot login to the CWB_IPM server with the given information.
Verify the password and server name and try again.
Error: Administrative Password Enable failed.
Use 'ipm password' command to enable Administrative Password after install.
Server Upgrade completed. Generating the IPM reports....
*** Error ***<BR>Could not connect to database: Database server not found (DBD: login failed)<BR></BODY>
</HTML>
1 ACCEPTED SOLUTION
Re: Problem with IPM installer doing "whoami"
You can workaround this by temporarily removing the other user ID, install IPM, then restore it BELOW casuser. But what files do you need access to as a member of casusers that you do not have? The idea behind casusers is that a CiscoWorks administrator should be able to do all tasks required locally that cannot be done through the web.
We do not support installations using sudo or uid 0 equivalent accounts (i.e. we never tested such scenarios). As a workaround, you can modify the /opt/CSCOipm/bin/ipm.sh script, and change the checkrealroot() function to use an id-based test:
ID=`/usr/xpg4/bin/id -u -r`
if [ "$ID" != "0" ]; then
However, the above caveat applies.
Blue
Because of the prior failure due to whoami, I had to uninstall IPM before another install could be attempted. Then I modified /product/CSCO/CSCOipm/bin/ipm.sh as shown as soon as I saw it created. Did this modification cause the pkg verification error?
INFO: Creating symlink from /product/CSCO/CSCOcwbS/db/CSCOipm/stopDbServer.sh
INFO: to /product/CSCO/CSCOipm/bin/stopDbServer.sh
INFO: Creating symlink from /product/CSCO/CSCOcwbS/vbroker/bin/osagent
INFO: to /product/CSCO/CSCOipm/bin/osagent
INFO: Creating symlink from /product/CSCO/CSCOcwbS/vbroker/bin/osfind
INFO: to /product/CSCO/CSCOipm/bin/osfind
INFO: Creating symlink from /product/CSCO/CSCOcwbS/bin/CWB_msgLogServer
INFO: to /product/CSCO/CSCOipm/bin/CWB_msgLogServer
INFO: Creating symlink from /product/CSCO/CSCOipm/clientSoftware/Solaris
INFO: to /product/CSCO/CSCOipm/htdocs/Solaris
INFO: Creating symlink from /product/CSCO/CSCOipm/clientSoftware/NT
INFO: to /product/CSCO/CSCOipm/htdocs/NT
INFO: Adding ipmAging utility to cron.
INFO: Updating properties files...
ipm.conf
INFO: Creating symlink from /product/CSCO/CSCOipm/etc/ipm.conf
INFO: to /product/CSCO/CSCOcwbS/etc/ipm.conf
Installation of was successful.
INFO: Checking Installation.
INFO: Package CSCOcwbS installed OK. Verifying... OK.
INFO: Package CSCOipm-s installed OK. Verifying... BAD.
ERROR: Problems found during Base Installation:
ERROR: Failed pkgs:
ERROR: Invalid pkgs: CSCOipm-s
ERROR: Base component(s) failed package verification. See prior ERRORS.
ERROR: ****
ERROR: The system will not be started due to an installation failure
ERROR: of one or more Base components.
ERROR: ****
============================- Error Summary -===========================
ERROR: Failed pkgs:
ERROR: ****
ERROR: ****
Started : Fri Mar 30 13:00:39 EDT 2007
Finished: Fri Mar 30 13:05:47 EDT 2007
Blue
Then I held off modifying /product/CSCO/CSCOipm/bin/ipm.sh until after
But eventually it still failed again. Does this mean I need to remove the whoami in IPM 2.6's setup.sh?
Registering IPM with CMIC...
Registering IPM with CCR...
Registering IPM with PSU...
Integrating IPM server with CiscoWorks Common Services... is successful
INFO: Updating Database Stored Procedures...
ERROR: Database Passwords not synchronised.
To use this product, set your path to:
/product/CSCO/CSCOipm/bin:$PATH
Check the documentation for supported browsers and versions.
The problem is not in the IPM installer, but still in the ipm.sh script. Since you are already uid 0, can you not do:
su - root
Then complete the installation? This will not require you to have root's password.
Blue
Good one. Never thought of that. I'll try that route.
Still the same error, even though whoami is returning "root" now:
Started : Fri Mar 30 14:28:02 EDT 2007
Finished: Fri Mar 30 14:37:07 EDT 2007
What does whoami report when you "su - root"? It really should say root:
marcus@rtp-christmas# \su - root
Sun Microsystems Inc. SunOS 5.9 Generic May 2002
# /usr/ucb/whoami
root
I have to use \su since I have an alias to su which builds my environment properly.
Blue
Wait, I take everything back. I just doublechecked on another box, that /usr/ucb/whoami
always reports "root" as long as the uid is 0, regardless of whether the account I su to is "root" or otherwise. So I've been "root" to "whoami" all along. There must be more to the real root than uid 0 and the name. Here's my previous query in Dec, 2006.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddcf365/0#selected_message
Doesn't look like there's any way around getting the root access.
What does ls -l /opt/CSCOipm/bin/ipm look like?
Blue
Since each failure requires an uninstall, these have been basically new installs of IPM 2.6.
ls -l /product/CSCO/CSCOipm/bin/ipm
-rwxr-x--- 1 a***d casusers 62068 Nov 30 2004 /product/CSCO/CSCOipm/bin/ipm
a***d is an App ID set up with the same UID as casuser, so I can manipulate the files owned by casuser without going into the uid 0 account (whose password expires every 24 hours). We knew casuser had to be above a***d in /etc/passwd, lest the latter takes over file ownerships of casuser. Your question prompted me to look at /etc/passwd again. It looks like somewhere along the line, casuser has been added to /etc/passwd anew. So now a***d is in the middle, while casuser is at the end of /etc/passwd.
Okay, that may be part of your problem. This is what is happening. The ipm executable does a getpwnam on casuser and gets back a UID. It then does a setuid call to that UID prior to executing the ipm.sh script. Part of this script's job is to check to make sure it's running as casuser. It does that by doing a whomai, and checking to see that the user is casuser.
So, if the UID for casuser maps to another username, you will break IPM. casuser MUST appear before this other username in /etc/passwd so that the forward and reverse mapping prefers casuser over this other user.
I can't stress enough how unsupported your configuration is. Not only will you break the UID/user mappings, chaning ownership of files breaks the package map. What you should be doing is putting your username in the casusers group. This will give you access to everything you need without messing up file permissions or ownership.
Blue
Well, I think we had that setup because there're certain LMS files laid down, owned by casuser (the user) but not writable to casusers (the group).
But isn't it a glitch (from what I can see) that the IPM install process removes the existing casuser in /etc/passwd and appends a new one to the end? The timestamp seems to indicate so:
-r--r--r-- 1 root other 9637 Mar 30 15:57 passwd
Yes, the IPM installer attempts to set casuser's shell to /dev/null regardless of the existing value. This results in casuser being taken out of its existing place in the file, and appended to the end. This can be problematic, but will not longer be a problem in LMS 3.0.
275
