Problem with lms 3.0 Dec update
s.fasel
since I installed the lms Dec update on my LMS 3.0, I have a problem to save the configuration of some 3750 switch and some Cat 4000 (with CatOS) in RME.
Ciscoworks writes that the configuration backup went correctly, but in fact, when we opened the file saved, only a part of the configuration was saved.
Somebody knows this problem?
Thank you for your help.
For information, my LMS works on Solaris.
Sam
Joe Clarke
I have not seen an issue with config file truncation. Where are you going to open the file?
I'm going to the directory:
/var/adm/CSCOpx/files/rme/dcma/shadow/Switches_and_Hubs/PRIMARY
It's the same result when I look these configurations directly in RME -> Archive Management
Thank you for your information
