problem with LMS 3.1 installation
the customer tried to install LMS 3.1, but during installation the following message appeared:
Cannot start OpsXmlDb Engine
The installtion is on the Windows 2003 server with SP2. What the customer has to do for successful installation? Thank you.
Roman
1 ACCEPTED SOLUTION
Re: problem with LMS 3.1 installation
Have them uninstall, or better yet, get the clean_system.exe tool from TAC, then reinstall using the following procedure:
* Set the TEMP and TMP environment variables to short values (e.g. C:
\WINDOWS\TEMP).
* Disable anti-virus and security software.
* Set Windows Data Execution Protection to be active for essential
windows files only.
* Login on the server's console as a local Administrator.
* Install from locally mounted original media.
Is this a new installation, or are they upgrading?
this is a new installation.
\WINDOWS\TEMP).
windows files only.
121
