Problem with send syslog messages to mailbox
Hi everibody I have enable define automated action but I don´t received any messages on my email account, I check the log files syslog.log and the syslog messages are there, and on file syslogcollector.log there a is many lines with error message.
SyslogCollector - [Thread: SyslogObjectForwarder] ERROR, 11 May 2006 19:38:35,816, Could not send syslogs, removing the subscriber...Connection refused: connect
I have restarted the SyslogAnalyzer process and even the entire server, but this does not help.
I'm running my CW on Windows Server 2003. version of RME is 4.0.4
Any suggestions?
thanks and best regards
Silver
Re: Problem with send syslog messages to mailbox
Got anything in your smtp.log?
RME knowns about you smtp server? If not configure it here
http://lms:1741/cwhp/systemPref.do
regards,
Michel
thansk for your response, it´s Ok The problems was exhange server, thanks anyway
Silver
smtp.log should show the problem with the exchange server.
Things like authentication failed, etc.
Michel
147
