Problem with the installation of CM 4.0.4
I have a problem with the installation of CM 4.0.4 , he starts unpacking his files ( this goes fine ) but when he should jump to installation screen the installation aborts without an error message.
Did somebody have has this problem before ?
We have a second CW2K server and on this one it functions fine ....
gr
wim
Silver
Re: Problem with the installation of CM 4.0.4
There should be a file like this
Ciscoworks_install_20060327_085948.log
in the c:\ root of your server.
That should give a clue
Michel
Silver
Hi Wim,
are there any messages in the Windows Event Logs?
And check the root fo C: there should be a file like this: Ciscoworks_install_20060328_160156.log
Please provide us with some more information!
Did you start the installation with administrator credentials? I had a similiar Problem with LMS 2.5 SP2.
I stopped the Daemon Manager manually and then installed the package.
Best regards,
Frank
problem is resolved, forgot to mention it is a windows box . Once and a while you need to reboot it to get the installation up and running ....
gr
wim
100
