Problem with view config in Device Center
Hi. I same have trouble with usertracking. To solve it i reinitialze the ani database and that solved the problem with usertracking.
After the renit i get problem with device center.
I can't see the configuration when i do view config in Management Tasks.
The error message is:
CM0003: Version 8 does not exist in archive 192.168.63.4 Cause: Version may have been deleted.
If i do edit config or looked at the config in config management, it works.
1 REPLY
Silver
Re: Problem with view config in Device Center
Try deleting one device and re-add it. Do Sync Archive for this device alone and check whether the issue gets resolved.
96
