11-20-2008 12:00 PM
I would appreciate if someone's fresh pair of eyes help me figure out my problem with importing files from remote routers into the software repository in CiscoWorks.
I submit a job and end up with a failure but the failure is basically about not being able to put file where it was said to be put:
Adding Image C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\wlanui.tar to Software Library
Failed to add wlanui.tar.
Reason : Exception occurred while getting Image Attributes
Adding Image C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\c870-advipservicesk9-mz.124-4.T7.bin to Software Library
Successfully added c870-advipservicesk9-mz.124-4.T7.bin.
Job Ended At : Thu Nov 20 11:05:50 PST 2008
Processing Device : Store 111 - Guildford
Start Time : Thu Nov 20 10:57:40 PST 2008
Device is locked for exclusive access.
The supported protocols for image transfer are: RCP
Connecting to the device using SSH...
Connected successfully.
Importing the image wlanui.tar from the device flash into the Software Repository.
Image will be copied to rep_sw_3406603696088408558 using RCP.
Copying wlanui.tar from flash to rcp://ciscoworks@192.168.14.4/C:/PROGRA~1/CSCOpx/temp/rep_sw_3406603696088408558
Successfully imported the image from device.
Total time for copying the image - 49 Seconds
Moving wlanui.tar from C:\PROGRA~1\CSCOpx\temp\rep_sw_3406603696088408558 to job directory.
Successfully moved to C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\wlanui.tar
Importing the image c870-advipservicesk9-mz.124-4.T7.bin from the device flash into the Software Repository.
Image will be copied to rep_sw_582371879415554160 using RCP.
Copying c870-advipservicesk9-mz.124-4.T7.bin from flash to rcp://ciscoworks@192.168.14.4/C:/PROGRA~1/CSCOpx/temp/rep_sw_582371879415554160
Total time for copying the image - 5 Minutes 30 Seconds
Moving c870-advipservicesk9-mz.124-4.T7.bin from C:\PROGRA~1\CSCOpx\temp\rep_sw_582371879415554160 to job directory.
Successfully moved to C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\c870-advipservicesk9-mz.124-4.T7.bin
Image Import from Device Complete
Device is unlocked.
Device Import Result : Failed
End Time:Thu Nov 20 11:04:43 PST 2008
SWIM0036: Could not add this image to software repository.
Eugene
11-20-2008 01:30 PM
Everything looks good here except that wlan.tar is not a valid device image, and cannot be imported into the SWIM repository. The system image, c870-advipservicesk9-mz.124-4.T7.bin, however, was properly added to your repository.
11-20-2008 01:38 PM
Yeah :-)
I figured it out a bit later. Thanks a lot, man.
By the way, is there any way to tell CW to allow storing files in the repository other than IOS images?
Eugene
11-20-2008 01:48 PM
The repository supports CatOS, PIX OS, etc. images. However, it only for software and firmware images. You cannot store arbitrary files there.
