Problems importing files from remote devices to CiscoWorks host
I would appreciate if someone's fresh pair of eyes help me figure out my problem with importing files from remote routers into the software repository in CiscoWorks.
I submit a job and end up with a failure but the failure is basically about not being able to put file where it was said to be put:
Adding Image C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\wlanui.tar to Software Library
Failed to add wlanui.tar.
Reason : Exception occurred while getting Image Attributes
Adding Image C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\c870-advipservicesk9-mz.124-4.T7.bin to Software Library
Successfully added c870-advipservicesk9-mz.124-4.T7.bin.
Job Ended At : Thu Nov 20 11:05:50 PST 2008
Processing Device : Store 111 - Guildford
Start Time : Thu Nov 20 10:57:40 PST 2008
Device is locked for exclusive access.
The supported protocols for image transfer are: RCP
Connecting to the device using SSH...
Connected successfully.
Importing the image wlanui.tar from the device flash into the Software Repository.
Image will be copied to rep_sw_3406603696088408558 using RCP.
Copying wlanui.tar from flash to rcp://ciscoworks@192.168.14.4/C:/PROGRA~1/CSCOpx/temp/rep_sw_3406603696088408558
Successfully imported the image from device.
Total time for copying the image - 49 Seconds
Moving wlanui.tar from C:\PROGRA~1\CSCOpx\temp\rep_sw_3406603696088408558 to job directory.
Successfully moved to C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\wlanui.tar
Importing the image c870-advipservicesk9-mz.124-4.T7.bin from the device flash into the Software Repository.
Image will be copied to rep_sw_582371879415554160 using RCP.
Copying c870-advipservicesk9-mz.124-4.T7.bin from flash to rcp://ciscoworks@192.168.14.4/C:/PROGRA~1/CSCOpx/temp/rep_sw_582371879415554160
Total time for copying the image - 5 Minutes 30 Seconds
Moving c870-advipservicesk9-mz.124-4.T7.bin from C:\PROGRA~1\CSCOpx\temp\rep_sw_582371879415554160 to job directory.
Successfully moved to C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1837\c870-advipservicesk9-mz.124-4.T7.bin
Image Import from Device Complete
Device is unlocked.
Device Import Result : Failed
End Time:Thu Nov 20 11:04:43 PST 2008
SWIM0036: Could not add this image to software repository.
Eugene
Re: Problems importing files from remote devices to CiscoWorks h
Everything looks good here except that wlan.tar is not a valid device image, and cannot be imported into the SWIM repository. The system image, c870-advipservicesk9-mz.124-4.T7.bin, however, was properly added to your repository.
Yeah :-)
I figured it out a bit later. Thanks a lot, man.
By the way, is there any way to tell CW to allow storing files in the repository other than IOS images?
Eugene
The repository supports CatOS, PIX OS, etc. images. However, it only for software and firmware images. You cannot store arbitrary files there.
325
