problems in bulk import in common services 3.1.1
I have a problem,
I need to import multiple devices to cisco works, I have the following file format:
; This file is generated by DCR Export utility
Cisco Systems NM Data import, Source=DCR Export; Type=DCRCSV; Version=3.0
;Start of section 0 - Basic Credentials
;HEADER:
management_ip_address,host_name,domain_name,device_identity,display_name,sysObjectID,dcr_device_type,mdf_type,snmp_v2_ro_comm_string,snmp_v2_rw_comm_string,snmp_v3_user_id,snmp_v3_password,snmp_v3_engine_id,snmp_v3_auth_algorithm,rxboot_mode_username,rxboot_mode_password,primary_username,primary_password,primary_enable_password,http_username,http_password,http_mode,http_port,https_port,cert_common_name
1.1.1.1,name1,cisco.com,,name1,,,,public_RO,,,,,,,,,,,,,,,,
1.2.2.2,name2,cisco.com,,name2,,,,common_RO,common_RW,,,,,,,user,pass,passSA,,,,,,
;End of CSV file
however, when i try import, as in the attached image, The following error occurs:CW.JPG
Import from file failed. Reason: Invalid file format. Line 7 of the input file has more fields than the HEADER
what is the error in my. csv file?
1 ACCEPTED SOLUTION
Re: problems in bulk import in common services 3.1.1
Try attached file.  The best way to resolve these types of problems is performing a DCR export from the server.  Then, edit this file using Notepad++ to include the devices you want.  Sometimes if you open with Excel it can change the format of the file making it unusable after saving.
to clarify, I'm sure the same number of fields in the HEADER is the same number of field devices
Please post the actual CSV file you are using.
the name of the archive is ciscoworks.csv
this is the archive:
;HEADER:
192.168.1.13,FDQ2345_BOG_Calle100,,,FDQ0011_BOG_Calle100,,,,COMM_RO,,,,,,,,,,,,,,,,
192.168.2.24,Sw_Cll12_P5_C1_01,,,Sw_Cll12_P5_C1_01,,,,CISCO_RO,CISCO_RW,,,,,,,usradm,Admin123,4dm1nLTDA,,,,,,
;End of CSV file
637
