Community Member
Problems of RME 4.0.2 to keep configuration from VPN 3005
I have 4 VPN 3005, in 2 RME keeps the configuration to me without problems in the rest no, the difference of the 2 that fails is that they are old hardware (2003), but with same versions of software, knows somebody that problems, the RME must support it?, thanks.
Community Member
Re: Problems of RME 4.0.2 to keep configuration from VPN 3005
Cisco VPN 2003 is not supported by RME 4.0 or 4.0.3. Refer to the supported list of Security & VPN devices.
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_device_support_table09186a00803f30ac.html#wp159372
Community Member
Hello thanks to respond, vpn is a model 3005 that was bought in 2003, these do not work with the RME to keep the configuration, those of year 2005 do not have problems with the same configuration and operating system.
110
