I became frustrated with device problems in my LMS 4.2 DFM module, so I decided to start from scratch and reinitialize the DFM databases using the procedure described by Joe Clarke in this document:
https://supportforums.cisco.com/docs/DOC-8796
I stopped daemon manager, then initiialized dfmInv and dfmEpm DBs with no problem. However, when I get to dfmFh I hit a wall. I issue the command to reinitialize and get no response. I have issued it twice. The first time I waited about 10 minutes then hit ctrl-C to cancel out. Now I have been waiting at least a half hour and still nothing. I haven't even received the Do you want to continue [y/n]? prompt.
Here is the command I used from within the NMSROOT\bin directory:
dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
Any ideas?
-Jeff
