Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problems updating RME Libinventory1.6
I use LMS2.5 & I receive an error when installing RME Libinventory1.6 from my ciscoworks server. The event log shows "Install Invoked by user : admin"
and a non specific error code?
Any ideas as to why i cannot install this upgrade from Cisoworks?
Paul
1 REPLY
Silver
Re: Problems updating RME Libinventory1.6
CiscoWorks has problem to recognize the latest version of MDF, and MDF 1.7 it's a requeriment of most this packages Cat1900, LibInventory, Rtr800, SharedInventoryCatIOS, SharedSwim2900XL, SharedSwimCat1900, SharedSwimIOS.
check that MDF 1.7 is currently installed.
Common Services > Software Center > Device update, click on Common Services
93
